Grigsbilly91
Is there a lot of bare wires, broke, cut and stripped wires ?
If not, unplug the terminals and look into them, use a maggit flying gass, ooops, magnifying glass, look into each individual end. If there is corrosion, clean them up. One of those hand held bead blasters from HF does an amazing job of shining up them connectors.
Just be sure that there is no way the beads can enter into the engine or the injection/fuelnsystem.
test all your connections at the bus bar for power. that is the distribution block and has some fusible link wires, one could be burnt and not sending the juice to the right places. if there is power at the bus bar posts, then check a little down each wire. you will see the transition from the fuse link wire into the actual wire. test there with a pointy test light for power
