Rodd
Recruit
Just remember if you are in cold climates the Dipacto has been known to fail. I recall seeing a thread about it a few months back.
SSD will sell them marketing +10 HP
That was purely speculation. I have one and have had no issues, and it gets plenty cold here.
how about right there,inside intake airstreamPersonally I enjoy having mine on the front frame rail. At most it will get a lukewarm while idling. Go for a drive and its even cooler
IMHO the front frame rail is the best. Air flow freely over it, nowhere for heat to buildup like inside the nostrils and in the event anything needs changing or modifying, its right there.
You're right it was speculation. I have been using one for over a year w/ no probs. IIRC there were 3 guy's in cold weather who said theirs had failed.
I got it covered with a 1" thick piece of styrafoam just to combat the heatrise after shutdown.Now THAT is some good craftsman ship right there. Very creative, and almost looks like it belongs there. Only thing I wouldn't like about that style setup is that while the truck is just sitting there idling or even after its been shut off the heat would buildup inside the plenum after disapating from the heat sink. Kinda bathing in its own heat if you get where im going.
Otherwise good idea:thumbsup:
Were those Dipacos failing in the cold or the REMARQ's, I do recall the REMARQs failing to start in cold weather
The alternative is to just buy a cheaper Dtech and the already made extension harnesses.
