Extremesounds13
So it has been a while since I have posted but I have been busy putting new mods on the truck):h and driving as much as possible to test them each before I added another. Over the last 2 months I lifted my truck(2 inches), installed firestone overload airbags, new HO injectors, new glow plugs, ATT turbo, and last but not least Devils Own WMI. Well I just recently got done with them all and all I can say is this is not even the same truck I started with!!!!!(this is a good thing
) I figured I would post this all together and break down each item as I added it. I have some pics also that I will try to get loaded up tomorrow. The first to go on was the lift which I did to get a little more clearance for the 33's that I am running. I researched a lot of options and with only needing about 2 inches of lift I cranked up the torsion bars and added rear lift blocks. The ride is a little stiffer but not that bad and now the 33's clear very nicely; they only used to rub on sharp turns. Also the lift gave the truck a more aggressive stance. Adding the bloack and cranking the torsion bars only took about 2 hours total to do and was about 75 dollars to do:thumbsup:. After I did the lift I added the firestone air bags. The reason I did this I because when I pull my car hauler with the Jeep on it or the big sled trailer the back end sags a couple of inches with the trailers attached to it. The bags were fairly easy to install(use a cobalt drill bit for the frame) and the kit was complete with everything you would need. I also installed a gauge and compressor so that I could fill and deflate the bags to the pressure I need from the cab. Now with the truck hooked to either trailer it sits nice and level, and you can adjust the air pressure as you drive depending on how heavy the load is, how rough the road is, and how smooth you want it to ride.
