dbrannon79
I'm getting there!
take the return line off and run it into a bucket running the LP and see if it will purge all the air out. are you still running the factory FFM? did you touch any of the hoses in that area or open up the filter in it?
if nothing else you can pressurize the fuel tank slightly with air, maybe 5-8 psi on it without risking rupturing it. and look around for leaks or use a spray bottle with soap to look for bubbles on the lines between the LP and the tank.
EDIT: disconnect the line from the LP going to the tank and run a hose into a jug of diesel and try it. see if that eliminates the air. if so your issue is behind the LP into the tank.
