Cali6.5
I would assume that Heath would have a turbomaster on his turbo and NOT the vacuum crap!
$1,400 is a lot for a turbo. Then again, Volvo wants $2,400 for the replacement turbo on my boat, bastards.
I assume the Heath turbo would tap into the stock vac pump wastegate actuator? And all the issues that go with that POS system?
Originally posted by BigT, $1400 is alot for a turbo
ATT is better price point and if you don't get Bill on the phone the support there sucks. Bill is one of the biggest ATT Haters out there cause he does'nt sell it. Quote "You can paint the stripe on a skunk but you still have a skunk" I love the skunk under my hood, gotten great service from Dennis and Leroy.
That price includes his new cold air box which looks to be real nice. The turbo alone is about $1100.
went to Heath's site to see it......no pic?....... Paveltolz you have a pic of it?
When I called Heath a few days ago asking questions I spoke to guy in the research department. He said the Super 84 is non wastegated like the ATT. He said I should wait for the smaller gated turbo they are getting ready to come out with. He stated the new turbo will have its own special turbomaster included. He indicated the top boost on the Super 84 is about 25 and the top boost on the new turbo should be 18-20. They will not be recommending head studs with the new turbo.
I am almost certain it is a Garret....He stated he preferred Garret turbos....
....From what I understand except in a few limited instances the only bad turbo is the GM factory turbo. Anything is an improvement...
Here's mine:
Non-Wastegated
Installed though now I'm using the OEM "Horn" upper intake to keep the boots from blowing off as the 3" at the 90* to the Peninsular is too short and keeps working out when holding 22psi.
It says A/R 60 on the outside but what's been done to the inside is a mystery to me.
Don't go hating folks, you won't get the specs on anyone else's turbo here either unless you buy it, open it, and measure it yourself.
Looks like a Chinese KO compressor housing?
Either way, guess he figured he'd get in on the game, and why not? There is a market. Some will prefer the ATT, some the Holsets like me, others his turbo. Pick your poison, none are really wrong.
What I don't understand is why nongated for dd and gated for towing.
Source Unknown
Source Unknown
It all depends on the wheels and the AR and what is chosen.
Who knows what's going on in Bill's lean-to anyways?
It might very well end up being only a wastegated version available for purchase. From Paul's posts, it kind of sounds like what they're playing with right now is a first "kick at the cat".
The welding on the downpipe to turbine housing would seem to indicate just that. If nothing else, Bill's stuff that is sold as "regular stock" always has a nice, clean, finished look to it.
Personally, if given my choice: I'd like to see and external wastegate solution with a header pipe (downpipe) that incorporate the exhaust rejoin further downstream. A lot of internal wastegates have problems with exhaust flow rejoin and turbulence at the exducer.
