Big T
I am curious how all of them loosened up. I did not use loctite when I installed mine after replacing buttons, but I’ll get a shot again when I go after the leaks and use the Leroy girdles.That's the plan. it's due for an oil change anyway. I had considered changing it before our trip to the coast since it was about 100 miles away from hitting 3k since the last change. now it needs it for sure. besides not knowing what caused that bolt to back out though the threads seemed fine and all the others were also not torqued (got another 1/4 turn when I checked them). if I have to go back in later for the same issue, I'd have to redo gaskets again along with what Will said about a thread repair insert.
I am curious how long it's been loose enough and the PCM constantly adapting for it trying to balance the injectors till it couldn't anymore and coded. I wonder if my fuel mileage will improve or have better power and responsiveness on the road now.
