On some trucks (Like mine) a bushing would put the 90* to far out and not able to be installed. My Burban has 599 with 3/8" and it hit the exhaust. I had to cut the manifold to get it to fit, so a 1/2" fitting would be even tighter.
506 bellhousing treads are metric
I bet they're notI'm certain my 98 bolts are 3/8", I'll have to check tomorrow.
You're talking about the 6 bellhousing to block bolts?I bet they're not
Bellhousing bolts on the optimiser are metric[10mm x1.5]. Bellhousing bolts on the "599" are standard thread[3/8 nc]. Motor mount to block bolts on a optimiser are metric[10mm x1.5] motor mount to block bolts on a "599" are 3/8 nc. A hydraulics shop or farm equipment shop should have the 1/2 x jic8 90 degree fittings.
GM used [not shure if they still do]to offer a conversion kit with all the bolts to switch to the 506 block from 599,660,141 or 929.
Good thing you didn't bet:hihi:Well my 98 506 block has 3/8" NC threads.
Sorry, no part #s. I got a bunch of parts from a guy that had a conversion kit in it. Bag is long gone.Woudn't happen to have a part number for that kit would you?
We're using the bolts we have available locally to get it back together (all grade 8 or better) aand I wouldn't mind switching them out for the proper ones later on.
I've got an aftermarket HD cooler and braided lines already on the way...
