Looks really good.Before and after. View attachment 47008View attachment 47009
Thanks Leroy!Looks really good.
I'm excited to see how it comes together.![]()
I've looked at the chrome under bumper balance LMC sells thinking about an intercooler behind that. Downside is you'd probably lose the tow hooks.
I could possibly angle it, but I'm not sure how much would be gained. I know it doesn't like it in the pic, but it isn't any lower than the factory air dam, so I don't think height will be an issue. Plus I want it fully in the air stream to get cooled as much as possible. Thanks for the offer, but I have the air dam that came off the hoe to play with.Purely a question, could you rake the bottom back so it would kind of match the angle to the engine cross memeber/ the angle the bumper has? Give you some more ground clearance? Not sure if it would be worth it or not. Even if not it still looks sweet.
Also I have an air dam from my Tahoe that has a cracked corner of you want it to mess around with for cutting.
I'm glad you asked. It's good to have extra eyes on it, in case there's something I missed!That's good. I was just curious.![]()
Yep, those are almost "must-have" tools. I use mine all the time.I love to live vicariously through others fabrication skills.especially till I can get a good compressor and welder.
Ok, the opening is roughed in. I think it's turning out pretty well. It's actually been a lot more difficult than I expected, but it should be worth the effort. Next step will be "molding" the opening into the bumper - that's where I'm going to have to really think about how I want the finished product to look. The hooks are going to be a challenge for not only how the finished bumper looks, but also for plumbing. I think some elbows and maybe a hole saw will take care of all challenges. Oh I will also be removing the drain petcock and just put a plug there since it's hanging down kind of low. View attachment 49381View attachment 49382View attachment 49383View attachment 49384View attachment 49385View attachment 49386View attachment 49387View attachment 49388View attachment 49389
So if I made some pieces that angle in on the inside of the sides would that do it? I see what you're saying, and as I was looking at it last night I realized that I should have made the opening the width of the core, not the overall width of the unit.If I may, you would be better served by reducing the area before that cooler and make it more efficient. The intake area should be only the same sq inches as the openings in your cooler between the cooling cross bars 'the area air actually flows through', you measure that open area then only have an intake opening that size "actually reverse of what most think is better."
When the area before the cooler is larger the airflow actually reverses because of the cross bars and side tanks and goes around the sides of the cooler at speed you will get some cooling but never near what you'd get with proper sized setup.
