FellowTraveler
Yes, it can and does...GM has a kit to delete the piece of &%$# at the p/s pump, its been awhile but I believe the plug to that little bastard is red and tied into the security system to, find it on d/s near the ac compressor...So could it give you a sense of abnormal "lane wander" or "loose steering" when driving on the Interstate, even after replacing all four ball joints, all the tie rod ends, idler arm and bracket and Pitman arm?
I checked the rag joint and it was solid (although I have contemplated the U-joint replacement) and while the Pitman was being replaced, couldn't feel any really bad play in the steering gear box.
