My mechanic says a 6.5 never steams out the exhaust
Not where from. Does the fanclutch bolt on to the waterpump with 4 bolts, or does the fan clutch spin on?
No thermostat will cause more rapid temp swings.
A blown head gasket will create the same on the pressure in the entire system regardless of the thermostat.
It is possible you have a thermostat stuck closed, took that out and sold that overheating problem . However a lot of people think thermostats are not needed. If they didn't need him the manufacture would not lose a lot of its profit making them, and the housing for them-they would just use the fitting to attach a hose.
No thermostat in the summer slows the get hot from the combustion leak. You got the whole rad to cool with from the begining. A quick 190° then the leak pushes it up from there fast. At the grape vine I through buckets of water through the rad until the temp drops way down and then proceed slow over the mountain waving at stuck people.
A quick 190 with the stat in.
Mechanics used to remove thermostats in the summer all the time. You needed it for heat in the winter they would say.
I have never heard a mechanic say this.
I have heard alot of shade tree jerry-riggers say crap like this though... :)
A thermostat is needed to provide a little backpressure in the system to make sure coolant gets through all the passages and does not allow any steam pockets to form. It is very important.
Thermostat removal very well could have been the reason you now have a cracked head or blown head gasket.
