Finally got the the truck up to my house, just put 2 hot batteries, about 5 gallons of fuel w/ a bottle of injector cleaner in it and it fired right up..
A few pics of the truck and engine before and after I washed it down.. Not to bad for almost 270K w/ no known rebuild...
http://s252.photobucket.com/albums/hh28/dragogt/K2500/
Known issues off the top of my head..
1. Dvrs door hinge is broke, door will not stay closed..
2. PMD need to be relocated..
3. Needs batteries.. (have 1 of the old ones, and a top post right now)
4. 4wd does not work..
5. SES light flashes on and off..
5. Engine oil leaks. (not bad but there)
6. front diff leak. (not bad but there)
7. Xfr case leak on front out put seal. (not bad but there)
8. Rear axle leak leak. (not bad but there)
9. Wheel cylinders leak. (not bad but there)
Starting to see a trend there... lol
Also on the more immediate side of things PCV?? needs to be replaced (dipstick tube was/ is puffing) looks like the turbo has some "blow by" also..
Also anything past about 1/2 throttle just dumps fuel I'll get a vid of it..
As I fix/ repair things I'll up date this thread. Right now its my DD, mpg is not bad on hwy but intown is horred..
