SnowDrift
Ultra Conservative. ULTRA!
Second, I don't normally openly disagree with what somebody says. But, anchor bolts in tornado alley, or areas that consistently deal with high winds are not over rated. Back in the dust bowl days in Oklahoma my mother, as a child, was in a house that was picked up by a tornado. Fortunately, the house was only turned and set back down, however it was no longer habitable.
Don
I was being sarcastic. If I was building a new building today, I would anchor it, without question. Aside from that, a house built in the early 1800s is built much differently than a modern building.
I wouldn't put money on anchor bolts winning an argument, though, if a tornado comes along. My wife and I watched (literally watched) as a neighbors house was sucked up into the sky. The anchor bolts may have held the sill plate, but didn't do much for anything above that.
When you pour your floor, don't allow the floor concrete to touch the outside block. It will transfer heat. I see you have foam against the inside block wall, but in some areas, it doesn't look like it is up to where your floor grade will be.
Neat project!
