turbonator
Boost hasn't changed much, since when the valve starts to open, the 18cm housing is just too big. Until headstuds this is what I have to work with, but damn does she pull hard. Still smoke free. EGT's have remained nearly the same since I boost a lot faster now. Max I have gotten to so far is 900*. I am sure 1000* can happen. Time will tell. I have only drove it about 10 minutes since I did it.
how did you come to the decision that it is an 18cm2 housing? just curious because we have ran housings from 12cm2 to 19cm2 and did not have much trouble spooling any of them with a 1\16 of a turn from tight on a .290" pump(could be that the genuine holsets spool better by design)... if i had to guess at the sizing of the ATT housings ( seems to be guess measures on the ATT) i would say that the original turbine housing would be an 18cm2 and the new one would be closer to 21cm2....
