I have a 92 chevy truck 4x4 5sp. Im building it for sled pulling.
Its a 85 6.2 out of a chevy van.
The motor has main bearing girdle homemade with angle iron, dished pistons, chambered heads, turbo precups , z28 sbc valve springs no rotators, head studs ,tried felpro 6.5- 10 over headgaskets they blew @ 60 psi boost, with stock bolts ,tried cometics and with studs constantly seeping,curently running victor rienz stock 6.2.
The turbo is wh1c holset 12cm welded waste gate. Im try to build power with high boost low compression and over fueling .
Ive tried lots of pump mods ,even 1/2 plungers wich worked fine for half way around the block,then snapped the cam pin. Currently the pump cam is locked solid.
Ive gotten enuff fuel from .310 plungers for 50 psi boost a turned up pump gives about 35 psi boost.
The 60 psi was with my big pump.Tonight i finely got running again with my new victor rienz head gaskets.
Ive only gotten 45 psi boost .IT does not run very well.
It wont start hot without cold water on the pump head .
My big pump is pretty much to loose, also the plungers seized one time so they are also loose. The head and rotor siezed one time also and i managed to cut them apart so head and rotor are not matched.
I can get a 4 plunger head and rotor from the central penn pump co. for less than $400 . So far im not very impressed with my combination . It ran best with the big plunger pump when it was new and marine injector tips .
I could pull out in 2nd gear and spin the whole way through when the turbo lit . Currently running 6.5 turbo nozzles that i modified .
Tonight it was cutting out a higher rpms. Not shore if its just the injector pump, my timing might be to far retarted.
It is hard to set when your cam ring is locked.
Also i dont think the wh1c is the right turbo for this combo ,the exhaust wheel is pretty restrictive , on a free rev it will boost 30 psi.
If any body thinks a 6.2 can really run im willing to try anything as long as it dont cost to much.
