buddy
Active Member
Why wouldnt 4 plunger work? Just need to be able to time the cylinders correctly, meaning put the lines to the injector in the correct firing order for the way the pump distributes it.
the db4 just spins the opposite way the ds4 does. thats it
The 4 pluger are .310 just like regular 6.5 but 4 instead of 2,peninsular also builds a 2 plunger .350 I ran a .370 rotor out of a john deere that worked good but it seized one time after I adjusted the timing. I had it at lebanon fairgrounds, it just spun it was over 2000lbs to light. I have to be pretty happy with it before I haul it to the Buck,we live in myerstown. Most people think very little of 6.2 ,6.5 diesels and say it cant be done.
sounds like that would be a heck of a problem wouldnt it spin backwords then on our trucks????? or would the lines just have to be routed to get the correct injection according to fireing order
I think alot of people would be if the price was right.And it wasn't finicky.
any body can get lots of fuel at lower rpms. Does any body know what is max plunger travel on the ds4.
It would take some work to get lots of fuel at high rpms probably 2500 and up and not be finicky, still not finished with my last idea,priced a head and rotor this morning,its close to 500 $. I might just get another one edm machined into a 4 plunger. If I could build a reliable 4 plunger pump with top end fuel I think it would be the first one , any body can get lots of fuel at lower rpms. Does any body know what is max plunger travel on the ds4.
