randomid25
Rattle-Trap Cap'n
Not to give your grief here Missy, but shouldn't this be in the 6.2 section? Great thread. I'm waitin on pics.
No mods needed
The 203 uses the outer shift arm to control the H-N-L function and the inner arm controls the differential locking sleave assembly.
There is no connection between the two.
The original factory shifter did it all with some fancy MONKEY motion and a few internal parts.
This kept it all neat and tidy on one stick.
The inner workings on the 205 are quite different in their layout.
The differential lock on the 203 is in the back of the box and the H-N-L is up front.
The only reason that the factory did not use two stick was of course esthetics and probably cost.
The times were changing and the push to make trucks look and feel less like trucks was well under way.
The auto hubs came out in the early 80's (YUK) and things have been changing every since.
My Daughter and Son inlaws 99 GMC just has a little knob on the dash for 4x4.
I keep telling the Kid that this (Pointing and the little electric knob) is NOT 4 wheeling. ):h
I am going to wait till I get things a little farther along and then I can fabricate the new "Twins" to that they will fit right through the original hole in the floor of the 91.
There are twin stick boots available cheap and then all I will need is a nice bezel to hold it to the floor.
I dont want to have to "HACK" the floor and the carpet all up. :eek
The 205 rails can be mod'd to allow the twins and If I remember right they can even be setup to run Front wheel only ????????
MGW
Hell I will dual post and irritate everyone.
I will put a 6.5 sticker on the truck to make it better ok
I can start the official "Project is off an rolling" thread over there :thumbsup:
MGW
