Second full day yesterday with the Blazer :thumbsup:
Still got some bad vibes in the drive shaft that are gonna hafta be addressed.
With a toally different shaft in there I know its not the shaft.
The dangle angle is definatley the issue.
Just going to take some time to work through the little issues that the new little beast has and get them fixed.
All in all for a 20 year old rig on a scale of 1 to 10 and 10 not being achievable I will give it a solid 8.
ODO shows 39000 miles and its probably correct considering the condition of the upholstery and the carpet.
PO had installed these tweeky "Billet" throttle and brake pedal pads made from alloy.
OMG these have got to go.
Missy is definately making a "MUST HAVE" list for the next trip to the U pullit yard.
The kewl little GRANT steering wheel stays for now anyway.
The Tach uis a POS, in the way and is going into the trash as soon as I can get a dry day to crawl in there and remove the wiring properly.
Going to snoop around and see if I can scare up a factory cluster with the tach that will fit that truck.
88-91 Burb cluster or the cluster from the later Crew cabs up to 91 should work fine. (Old style body)
Drivers door window regualtor is fouled, motor runs but no Joy.
Great job for a nice warm afternoon me thinks.
Got to order a new rear rubber brake line as the fools that installed the dual exhaust allowed the line to rub on the pipe.
Looking over the Purchase warranty on the tires and the PO had them installed on December 21st
Still got the nubbies they do.
I am going to see if the 35-13.50 X tires/wheels will fit the rig with just the 4 inch lift. If they will clear the fenders without issue I will put them on and be done with it.
The new tires that are on the rig are a very conservative tread and will wear great on the highway but are not going to give much Joy in the sloppy stuff.
OH BTW someone (Previous owners) ??? had done a sweet job of placing all the underhood wiring in these RED wrinkle Looms.
OMG RED, what were they thinking.
Its neat and tidy so it can stay, BUT RED
Starting to formulate my plans now for getting the 6.2 diesel in this thing.
Just as soon as it warms some I really need to get off my tushy and get the 87 Burb ripped apart and the goodies all cleaned up and ready to go into the Blazer.
Also, last eavening we had passengers in the back seat, and the complaint was made that the seat felt loose.
Hmmmmm looked it over and discovered that the seat was snapped into the rear locking lugs but the front HINGES were not bolted to the floor.
One of todays tasks is to get that taken care of.
A couple bolts with large washers will fix that issue right quick.
I would like to have the original type fasteners that were used BUTTTTTTTT these rigs are not prevalent in the bone yards so I will have to improvise.
Can't have the seat flopping around all over the place.
Off to get more coffee.
Missy
