vdb11
Halfmoon Detroit #2
6.2, I didn't realize there were different springs, is it stamped on the spring? Also I didn't really think about the metering valve, that makes sense that the plungers do not reach full travel because the valve controls how much comes into the pumping chamber. I have a question about the governor. Is the governor always acting against the throttle position. From what I understand in reading the manual, the weights, which swing out a certain amount depending on rpm act to pull the metering valve through the linkage and spring closed while the throttle shaft is trying to keep it open. Is this a progressive force? What I mean is the weights are always swinging out when the engine is running, so they are always applying a force to close the metering valve, the strength of which is determined by how fast they are spinning. So the governor spring keeps the force from the weights from closing the valve, but as rpms increase, the force from the weights increases and therefore begins to overcome the gov spring and pulls the metering valve closed. This is progressive right? The reason I ask is because I was wondering if a stiffer spring would keep the metering valve more open through the rpm range since the gov weights can't overcome it as well. It would also increase the max rpm I guess but I am not too worried about that.
turbonator, I am thinking somewhere between 20-25 psi max. I know right now I am overboosting for the fuel I have, since I have the VGT too close to closed, and the IP being worn out. The truck almost never smokes and thats with a standard, but I am not that hard on it either. 950 with that much weight., thats really good for EGTs. I can hit 900 going up a short, but steep grade near my home, but I usually am in fifth , which puts my rpms a little too low to build boost (I can hit 12 psi) and it somewhat bogs.
Slim, I talked to Gary last night and he is going to use hardened material, and he is going to match the factory plungers. He said he was going to use reamer blank, which he had in .375, .390, and .406. I told him to use the .390. He said he may not have any of that in stock so I told him to use the .375 if he has no .390 material. I also opted not to have the charge holes enlarged. I will start out with the fuel turned down a good bit, and then work towards a good spot like you said.
I see what you mean about fuel delivery, it makes sense to me that it should take less throttle to get down the road, so theoretically mileage should be similar I would hope. But that's if I can keep my foot out of it. I wouldn't mind more touchy as for some reason my throttle seems to have a decent bit of resistance (??), maybe something in the linkage. This is in comparison to our 95 t-tag which is by wire and the pedal is so soft and touchy.
As far as heads, I will hold off for now and see what I can get with this combination, although I do love to experiment. Same with the precups, I just bought new ones. Sounds like you may have turbonator as a guinea pig
