It idled up and down,pretty much any were it wanted to. I think the four plunger .310 DS4 or DB4 is probably the biggest size needed to get 400 + hp. The problem I see with the DS4 is that it 's cam ring has no lobe. The other problem is that the fuel metering solenoid needs to be tight shut at full throttle . Excellent plunger filling design on the DS4. I have considered trying to run one of these with a push button switch or pwm,no computer,the advance could be made mechanical. I'm not convinced that the stock prechambers are bad. My 6.2 had the smallest precups ,and I put the big pump on and the horsepower was extreme. but only untill it broke the cam pin,and seized the plungers. I later changed to turbo precups,but didn't notice anything,keep in mind there was lots of variables in my testing as I was always changing multiple things at a time,and getting very frustrated and confused. I discovered my 6.2 ran better with the timing retarded than advanced. I have seen egts on this thing over 1600,not sustained, and the cyls and pistons are fine. It didn't melt anything. It didn't crack the block or crank. It just blew head gaskets,and spun the main bearings, maybe from a bad homemade girdle ? I'm convinced most my tuning problems were from the dished pistons.. Did you notice more power with bigger prechamber openings ? This is something I might try for my 92.
