DieselSlug
Well looks like the net issue with the truck is knocking on my front door...
Been experiencing some vibrations at 70-75 MPH on the highway. Lately those vibrations have gotten worse and now start at about 60 MPH up to 75 MPH. you can feel them in the steering wheel sometimes leading me to think its the front end. Did a quick look over of the truck first thing this morning checking the u-joints, as that's what i figured would be bad. Both front axle u-joints seem tight with no play. As i grabbed the axle shaft at the joint I wiggled it up and down. There was a good 1/4 of play on the drivers side. Passenger was a little less, but still more than i would have expected.
Did a lot of searching and it appears if my diagnosis is right this is a common problem. There is a needle bearing in the back of the hub assembly (unit bearing) that supports the weight of the axle shaft itself and that's what the axle shaft rides on in the knuckle.
See the how to made by a gent on the Ford Truck forum: http://www.frontiernet.net/~jmray/F250NeedleBearings.htm
I ended up giving the misses a ride to work today and left the truck home. After researching I really think this is my issue, so out to NAPA to get (2) needle bearings and (2) outer axle shaft seals. Grand total of $180 (Man, I miss my GM IFS, never costed me this much even plowing!)
Hope to find out tonight what the issue is exactly. I did not check the front and rear driveshaft joints as my driveway is a slop hole now (yup 60 degrees in February..) This truck also has a carrier bearing that I want to make sure to inspect tonight also.
