Also keep in mind, offset grinding the crank is also an option, -that COULD yield another .010" -if needed.
Again, not a first choice, -but still a viable option.
In my opinion, -a 19:1 motor will still open a huge door for safe elevated boost levels.
The Mahle's and Zollners I've seen sure look like ceramic, -with carbon graphite skirts.
Sure is a shame we can't get these anymore.
I've got a brand new SCAT crank sitting in the garage- I dont want to mess with it other than for balancing.
The mahles i ordered are hard anodized- doesn't say anything bout ceramic.
And yeah its too bad the are discontinued- i had them search high and low for these and they couldn't even find any in stock in any of their stores or warehouses- and i checked a couple companies.
As Packratt stated his combination would work well with .005 shorter rod for a 20:1 motor. Add a .010 thicker head gasket and you would probobly be arount 18-18.5:1. Also even though the piston might be listed as a specific compression ratio, by the time everything goes together it rarely is the compression ratio stated. Proper machining of all components and block are required to achieve exact ratios.
yeah i think i will get the .010 thicker gasket to go with my pistons. And i realize the numbers aren't exact- however, i am having a machine shop machine the block and balance the rotating assembly etc. this shop has a good reputation and has done many 6.2 and 6.5l's.
Add in the question of is it really necessary to go to 18:1, if staying with stock boosting levels there is no reason IMO to go there, it's only when going 15+ sustained non cooled boost where one needs to explore this option. IMO save the $$$ to splay and 18:1 piston, for a better crank, Fluid damper, cooling mods and better turbo like ATT and drive on.
Well, i don't need to go all the way down to 18:1- 19 or 20:1 is alright by me. I already have a lot of mods to this truck and i don't plan to intercool. - however the GM-4 is going on the '87. i have an ATT sitting in the garage:thumbsup:.
Also upgrading to '97 cooling and '99 heads, SCAT crank, main studs, and head studs amoung other things, i was gonna go fluid damper but just ended up getting new stock balancer and pulley (figured this should be fine with the SCAT and main studs and saves me about 400 CAD-stupid exchange rates :mad2
finally got a pyrometer too- when it blew the boost levels were fine (about 12 sustained, 15-16 peak) but i guess the EGT's could have been to high- stupid on my part i geuss.
Jpeart: where in Kelowna are you? I have probably seen your truck around town.
I live in westbank now, but i used to live and work in kelowna and still get across the bridge quite often. I stopped driving the '95 in september, so if you've seen is since then its not me.
Ive been driving the '87 since. its rusty and white and silver on 31"s with white rally rims. barn doors, cab marker lights, sagging rear springs. loud.):h
before the '95 it was the black/grey and red 86 blazer. lifted 3" on 33" BFG mud terrians, big winch bumper w/ lights, boat rack.
If you check my garage on the 'Place there are pics of the '95 and the '86.
