chevyinlinesix
Eyre Flow Headers
As always my goal is to correctly understand things, & spatial orientation isn't my strong suit, so I draw things out.
Here's a drawing of how I understand changing rod length, piston pin height, or piston crown height affects compression ratio. Granted I pictured cyl area instead of volume, but as the bore stays the same.....
I believe the comp ratio calculator on the Silvo-lite site only includes rod length in the dynamic comp ratio calculation.
That's because it doesn't affect static compression ratio.
The only thing rod length is changing is the distance between the crankshaft journal and the piston pin. It does not change the total swept volume. All it does is move the pistons location in the bore. Take 1/2" off the connecting rod, and it will make the top of the piston 1/2" farther from the deck of the block (which makes it seem like the compression should drop because there is now more chamber volume) however, remember that when the piston is at BTC it is also 1/2" further down in the bore.
Here is a simple test: Lay a ruler down on your desk (beside your beer ):h ) and grab a good length pencil. Hold the pencil at midpoint with your pointer finger and your thumb, and put the tip of the pencil at the 1" mark on the ruler (hold the pencil parallel with the ruler) Slide the pencil down the ruler to the 4" mark and then back up to the 1" mark.
Now, grab the pencil at the eraser end put the tip of the pencil at the 1" mark on the ruler (holding the pencil parallel with the ruler), slide the pencil down to the 4" mark, and then back up to the 1" mark.
In both cases you have a 3" stroke, and in both cases you have a 4:1 compression ratio. Even though rod length (represented by the pencil) has changed, neither compression ratio, nor stroke has changed.
