So it isn't real clear to me. It's the head that has the low spot? Have you checked the block?
Exactly.Just what I was thinking.
Summit racing sells a precession straight edge for around $75. Add a set of feeler gauges and then you won't ever have to trust someone else's work. You'll be able to check it.
If you believe the gm service manual , It says not to resurface. Replace
I remember reading somewhere that they had to be surface ground because a milled finish wasn't smooth enough to seal properly.
