standard cab/ long bed it is 34 gal (US), ext cab, I believe is 26
Has anyone tried to replace their 26 with the 34? Is it just a bolt in? Is it worth the effort?
I'd like a bit more distance between fills. I've been thinking of dropping the tank to adjust the float on the sender: it reads full for a long time, then drops like a rock. Cleaning the sock couldn't hurt either.
If a 34 gal tank fits, then I'd rather expend the effort and put a larger tank in.
Cheers.
Mike
34 won't fit a short bed.
I think its the nature of these trucks that the fuel guage read full and then drops really fast to "E" at about the 1/2 full mark. I think it has alittle to do with the shape of the tank (think of a cone shape).
I'm very happy with my 50 gallon bed tank and 34 gallon main tank, range of 1500-1800 miles on highway, hope it improves to 2000 when I get around to buying an ATT.
I think even an extended cab short bed could come with 34 gallon tank. We had this discussion a while back, and it seemed that it was cab dependent not bed length.
It is bed length that determines the tank size. Any longer and it will hit the rear axle. The 34 gallon tanks are longer from where they bump up behind the rear of the tank.
My 45 gallon tank is made by Transfer Flow and fits in the stock location. It is very well made, and has multiple baffles.
It's part #6954. It's been under my truck since about 3 months after it was driven off the lot, and has been a quality piece. What do you want to know?
