lights
kyle675
My low beam lights went out in my truck the high beams still work and all running lights work I checked all fuses and are fine and I took the relay for high beams and switched with low beam and still stayed the same what else could it be the switch itself? And if so is there a way to check it to make sure?
Buddy of mine just went though this.
In his case it was the engine bay relay connection (the one adjacent the firewall and brake system). Poked around with the wires coming 'up' to the relay and found one of the connections was lose as the low beams then would pulse as he played with one of the wires. Pushed all of the wires 'up', made sure the relay had good connections, and now his low beams are back to life.
