You have that DS4 mess otherwise I would send you the "classic" FR
B-5 Walbro PSI rated for a DB2 off Patch . It 8 years of use outlived the truck and a few engines... I used a single "grade 8" 1/4" bolt to hold the Walbro to the frame with an existing hole at an angle.
OEM's are using in tank lift pumps now and some around 50 PSI. Yeah, with my luck on lift pumps (looking at Fass and Airdog's reputation no longer bulletproof ) I considered via attempting to install a belt drive oil pump style lift pump, but, it wouldn't fit the larger 6.7 damper and fan on my 5.9.
A Carter with the fuel cooled motor I tried didn't last long on biodiesel. Made funny noise before the weekly oil change and fuel PSI test could catch it dead.
A call to Walbro to verify specs on a FRB-11 may help. Their number is here as well as a past discussion on rated life of their models being ~50% less on some.
My FRC-10 gave up the ghost and I'm having a hard time finding a replacement that isn't special order with a long lead time. Does anybody know of a place? I don't run the truck alot so not real keen on spending a bunch of money on an entire new(insert brand here) setup.
www.thetruckstop.us
