94DieselSub
So about a year ago on one of my summit racing visits, on an impulse bought a Carter P4601HP. My thoughts are yes some have complained about them failing on diesel.
But - years ago I came across a forum (don't know which one) were a member stated he thought his Carter pump failed. He got a freebie warranty replacement, so he opened the 1st one up to find a plugged up SS filter screen on the inlet side. Cleaned it and found the pump was actually fine.
So perhaps those who thought their Carter pumps got noisy & failed, maybe suffered from the condition? Apparently said screen is somewhat easily removed.
The P4601HP is diesel rated, flow-on-fail, 18psi max, 6-9.5psi @ 50gph. Now I installed a large baldwin pre-pump water separator/50u Filter, and a 7u absolute donaldson filter before the DS4. The leaky pos oem FMS got deposited into the round-file!
So when I get around to installing this Carter, I plan on regulating the idle pressure via an adjustable pwm buck voltage regulator. Set point of say 10psi at idle at the discharge port of the 2nd filter. The discharge port of the 2nd filter will also have a 8psi low pressure switch. Said switch will trigger a dc-dc SSR that will bypass the voltage regulator, thus allowing max available lift-pump pressure.
I don't plan to run any more bio than the 10-15% already mixed into pump #2. So I feel somewhat confident that this Carter should last awhile. If and when I get around to installing it.
