Yachtcare
Recruit
- Messages
- 173
- Reaction score
- 2
After some considerable digging thru the cryptic Delphi website I was able to access their 2005 feed pump catalog online. (Yep, 2005 seems to be the latest version available). The spec for the hpf923 which is the pump that the hpf953 replaces were 50gph @ 10psi, with "psi shut off" at 18. The hpf953 is supposedly "improved", so one could assume (perhaps dangerously)that the specs are at least the same, or a bit better than the 923 pump.
Comparing that to the frb 5, it seems as if it might be a decent fit.
If I do a setup like Turbine Doc's, and leave the airtex in line the issue of flow on fail may not be such a worry, as the airtex could still get me home if the hpf failed.
Anybody see flaws in my logic?
