Thanks for going to all the work for us! It makes the swap easier and quicker. By the way, sounds like my chevette diesel did...isuzu power!
leroy, you need a shop because of all this rain.
few q's:
is a WTA IC really necessary?
what is the purpose of the p/s gear fitting?
is the Engine to trans adapter still avail? was word the guy was hard to reach.
if wishes came true and i already had the optishift, had the engine/parts, it would cost a little over 2000.00, if i didn't really need the WTA IC.
i had no idea what the silencer ring was, thanks for the pics/explanation. are you gonna run some test to see if there is a diff?
These are the expences put out on the swap.
Donor truck $3000 Could be done for less
Engine hoist ram $49.97 Optional
P/S gear fittings $44.04 Optional
Bat cables $75.00 Optional
V belt 15460 $9.71 x3 Optional if yours are good.
Dayco Rad hose $13.99
4bd1 oil pan $100.
203 pilot bearing $4.95
Turbo drain tube $12.95 Optional
Rad over flow hose $2.15 Optional
Welding gas $23.64 and $46.85 Full bottles not all of this cost applies here
Coolant recovery bottle $7.99 OptionalThermo Tec header wrap $53.99 OptionalTrans cooler hose $9.00
Glow plug controler $75.59 Optional
Camera tripod $15.12 Misc cost
Trans fluid $45.
Engine oil $30.00
Oil filter $20
OptiShift $600
Engine to trans adapter $680
Intercooler $200 Optional
Silicone elbows & clamps $100 Optional
Turbo $250.00 Optional
T3 flanges $24.00 Optional
Exhaust elbows $60-80 Optional
Misc $300-500
Total $6093.36
I know I missed some stuff. Ya'll let me know what.
I still have the 6.5 that I will be selling. Assume selling at $1900
Scraped the NPR frame & cab for $500.
Cargo Box worth $1000 to me.
Total $3400.
$6093.36
-$3400.00
=$2693.36
Not yet, but did get some good highway miles on it this last 250. Will top off tomorrow and report the #sThis is awesome info Leroy. Any hwy mpg numbers yet?
Just stumbled onto this thread today, totally awesome job, Leroy! I've considered/daydreamed of dropping either a 4bt Cummins or now maybe a 4bd Isuzu into my '98 K2500 Burb when the 6.5 finally gives up the ghost, but with 199K on it that may be a while. I'd yank the 4L80E and drop an NV5600 into it if I did. Can't wait to see some long-term city/hwy fuel mileage numbers once you work the bugs out and have it to the point that you're willing to take a 500+ mile road trip with it, as well as some RW hp/torque numbers off a dyno. Could your low boost numbers be because of too big of a turbo on it, would a GMx work better (no, I do NOT want to start any of the flaming wars I saw over on the Place concerning turbos, that's why I'm here, instead) as it is as much science as it is art finding the right turbo for the application/intended use from what we have to chose from.
I would love to put it on a dyno. The turbo should be good for this motor. There is an ajustment screw holding me back from full throttle that I need to ajust and my shift points a set for MPGs. There is a second table that I can set up on the OptiShift for more performance or towing.
Well, lacking the accessibility/$ for a dyno run, there's always the fairly accurate standby of using the vehicle weight/time through a 1/4 mile drag to get a fairly accurate hp/torque "guesstimate".
Thats a good idea also. Do you have the details how to calculate it.
If I was'int lazy and going to bed now I would google it.
