Matt Bachand
Depends on the 6.5
There are 4 holes in the filter manager where fuel can pass through.
1. Input from LP
2. Output to IP
3. Output to T-valve
4. The black valve on top of the filter
Obviously they all have their purpose. The main purpose of the valve on top of the filter allows you to get the air out of the fuel lines and filter manager. The cleanest way to use it is connect a 1/4" clear tube to it and put the other end in a container. Turn the valve counter clockwise and open completely until diesel flows out in a constant stream w/ no air bubbles or spitting. I found the easiest way to jump the LP is to run some trailer wire from the driver side battery to the LP. Let it run until fuel flows free.
On OBD2 vehicles there is a 'lift pump diagnostic' connector right past the underhood fuse box. By connecting that to the positive terminal with a foot long length of wire, it runs the lift pump. No need to go all the way to the LP physically.
TD Discovered this and its in the stickies and other threads.
Installing a momentary switch permanately is a great idea so you just press the button, then tighten the fuel flt bleeder when air is out.
Great find TD!
