ak diesel driver
6.5 driver
I thought all the wiring and such was on the bottom of the powersteering pump. I guess it would have to tie into the steering somewhere. wierd on the abs light tho
I posted an error.
ABS light stays off,it was the E brake light that was on.
Must have leaned on the pedal when i was farting around under the dash,releasing the pedal made that light go off as well.
So it appears disconnecting the steering position senser doesn't cause any issues.
Try it... You KNOW you're gonna...Still eye balling the 95 steerbox,itsat me so sweet
Thanks for the tip Doob,i didn't think of that.
No reason though for the CV to lock up going straight ahead and in 2 wh drive.
That may change with a tire rotate.i went to the wheel alignment shop again yesterday to check the whole shebang out again and have the steer wheel centered.
I was on the bridge for damn near an hour and a half,they checked and measured everything and didn't find a damn thing wrong with it but they fine tuned toe in,camber and caster to as close to perfect as possible.
On the way home the truck now pulls steady slighty to the right:???:
