did the gov squash this like the delorean? and x2 on the pics!
you mean the Tucker?
Crap...sorry for the issues. I hope you get them worked out soon.
Thanks for doing this - I am very much interested...:thumbsup:
Pics? :drool5:
Ok I am having a Hydrogen generator installed. My truck average 17 - 18 mpg in town and over 20 on the highway hand calculated.I will let you all know what if any results are. My only problem is I just put new tires on so don't if that is going to effect my mileage.
<snip>The problem we are having is with the large volume of air our great trucks generate, we were sucking all the water out of the secondary bubbler tank into the motor. I am putting together an electric valve system to close the valve when we reach and certain amount of vacuum to keep form ingesting the water. while we redesign the bubbler tank with baffles...
Hello John,
You may want to consider installing a vacuum pressure relief valve on the bubbler tank, or in the piping that runs from the bubbler tank. There are several positive pressure relief valves available that can be converted to operate as vacuum pressure relief by simply reversing the poppet and spring. Trick is finding the valve with the right pop pressure value, but it's simpler than the electric valve setup.
Regards,
Franko
Well I tried that. I currently have a oil breather 1/4" NPT on the tank for vaccuum release and I still drain the tank. That is why we are trying to do the valve and or baffles in the tank with a vaccum release.
Gotcha. Do you use a vaporizer (a.k.a. scrubber, condenser, etc.) tank? It should be installed between the bubbler tank and air intake system, mounted around same height as bubbler tank. Many setups do not use the vaporizer/scrubber tank thinking the bubbler tank will do the job. Can you post pics?
Regards,
Franko
