buddy
The difference between the GM turbo and any HX40 or ATT is that the fueling will more appropriately control how much boost you get, and not the PCM. The GM turbo is so small it has to have the wastegate controlled a lot, and not so on a larger turbo. EGTs and a safety net is all about fueling level. If you want that safety then youre looking for stock fueling levels and about 12psi of boost, but you wont like towing 10k lbs like that. The 6.5 and HX40/ATT are capable of a lot more safely.
I would be looking for a typical performance level program, that maxes out the GM fueling curve at 80mm^3 at 2100psi to 3300rpm, but no more fueling tweaks. And no extreme advance, but more than stock under load because it will help lower EGTs with more fueling. Get a controller that pops the wastegate of the HX40 around 15psi of boost. That and a good set of injectors will get you far (which I recommend set to pop at 2300psi). Assuming you already have a 4" exhaust and a decent cold air intake.
You foot becomes the factor in how much fuel and boost you get, but you should not have any issues with a setup like that. Sometimes it becomes dangerous not having the capacity for more power, because at times going too slow is both frustrating and harder on the engine not having any air flow, so the fan must take more power from it. That and all the little racers on the highway flying past you.
