Acesneights1
My only concern with ATT on THIS is if I run it through a fairly large ATA( just because I can...
) will it suffer substantial lag ? Otherwise it sounds like the way to go. Initially I probably won't run an ATA anyway as I really want to see how hot it will get towing with the old school rad and puny 6.2 WP. I am planning on swapping the front of the motor over to all 6.5 accys since a 12v conversion is in order anyway. It should all work. the reason I have always loved GM is they make everything interchangable. What other vehichle could you swap a 1983 steering box into a 1969 ? (with minor hose adj)
