Samyguy
any body running an holset HX-35 on their 6.5 TD ??
what do you guys think of these?
My kid is running these things on his cars, here's a link to some of their stuff.
http://www.dsmtuners.com/forums/turbo-system-tech/353498-holset-turbos-part-7-a.html
Alot of info there on Holset turbos
Really my point here, is I keep seeing folks repeating turbo A is better than turbo B without direct experience w/ both turbo's. Unfortunately, the list of 6.5'rs that have run more than 2 non-stock turbo's is VERY short.
28, 32, 50 psi? On a GM 6.x block?
Now there's a real buildup story I'd be interested in hearing the fabrication of... care to share the details?
SmithvilleD,
Since you are running 18:1 what is the boost level you are running now? And since you dropped your static compression, how much boost do you think your engine would handle?
