FellowTraveler
I wish I had space for a condenser fan, I have so much going on up front w/2 aux trans coolers, engine oil cooler and 2 aux p/s coolers so I've been considering a roof mounted condenser box fan setup from RED DOT because I need room for my big Cummins CAC/IC.You can only pull down to whatever atmospheric pressure is. I want to get a micron gauge one day to test my pumps to see what they actually do. The fastest vacuum pump I have ever seen is a snap on air one. It can pull my 4+ lb system down to 30 on my gauges in well under a minute, but it does sliw way down pulling the gauge down to 32. I've seen several electric pumps that can't pull either of my gauge sets to 32, but that little air one can. My electric one is slightly slower at 1st, but goes faster once the vacuum gets down to 30 and it kicks to the 2nd stage. A bigger pump just means it pulls a system down to atmospheric quicker, but it still takes x amount of time to boil out any moisture or remaining refrigerant(please for the love of GOD! DON'T CALL IT FREON! IT'S REFRIGERANT!) left in the system. Need to get out and pull mine down so I can put my fan pressure switch in to actuate my electric condenser fan.
