Matt Bachand
Depends on the 6.5
Update
Active Codes
PO 251 Inj Pump 'A' Rotor Cam Problem (Proved this False with followup test)
PO 266 Cylinder 2 Blance Fault
PO 281 Cylinder 7 Balance Fault (This is the Cylinder that idle DIDN't Change when cracking, THUS, problem Cylinder)
PO 370 Timing Detect High Res Problem
PO 1216 Fuel Solonoid Response TIme Too Short
Those are the codes.
Cracking cylinder 2 injector, Idle got worse. Cracking cylinder 7 injector Idle Stayed Constant skipping rough
Swapped 5 and 7 Injectors.
No Change Was hoping for change.
Garage I was at didn't have Diesel Compresssion tester, my mechanic (buddy of mine) was going to borrow one tonight. But I bought one at Harbor Freght foer $26.00 Diesel Compression Tester with GM/Ford/Dodge fittings. Great deal
Tomorrow morning will test cylinder. I don't think there is compression.
When the truck is idling, I can hear a 'spfffft' sound. Its sounds like the compression is sqeezing out of somewhere other than it should be. We will see what the Results are. My money is at 0 at this point.
To be prepared for tomorrow, what should be tried next? Remove valve cover and see what top looks like, and make sure the connecting rods are still intact?
When cracking fuel on cylinder 7, some did come out of the line, so I know fuel is in therem, besides the obnoxious cloud of unburnt raw diesel is double conformation. It must not have compression or it would be firing that fuel.
There was no change swapping injector with cyl 5, which has proven to be good.
Still no sign of ANYTHING in my engine oil, No diesel fuel, not overfilled, and defanately no antifreeze. Oil looks/smells its normal self.
Coolent level remeains the same.
Oil Level remains the same.
So Now, assuming compression fails on cylinder 7, perhaps a valve is stuck/broke and allowing no compression? Perhaps its coming back into the precup?
I know need to verify no compression, and will so tomorrow, but if Compression was there, i probably wouldnn't have a problem now as I verified injector good, and I know fuel is getting in there, because my eyes are still bleeding from driving like that.
Thanks again for all your help guys, and I knew exactly what to test at the garage, once again all thanks to you guys. Even knowing Harbor Frieght had a diesel compressiion tester, not only cheap, but available, as other places didn't, thanks to you guys. Chrisk1500 comes to mind, not sure if he mentioned it or not, but goes to show reading/contributing to these forums even when not having a problem helps you 10x over when you do.
Active Codes
