dbrannon79
I'm getting there!
Hey guys, continuing on my 93 trying to restore it to as much as I can "Unmolested" stock setup. I need some help with the IP. the PO had installed a military IP that is 24v for the fuel shutoff solenoid. I have a 6.2 on the stand which has a DB2 of unknown condition. At some point I would like to test it and see if it's a good spare, but for now I want to get rid of the remote solenoid the PO installed on the return line for the 93 truck.
I am planning on pulling the intake to install a factory TPS for the TCI TCU and remove the cable driven TPS for it, so I might as well get this swap done at the same time.
the goal here is to return this 93 to as close to stock configuration as possible to in my mind make it last. these things include getting the factory fuel shutoff to work as it should, and checking to make sure the fuel screw is adjusted correctly. I also need help with that too.
So I guess my question is in two parts here. 1. how to swap the fuel solenoid in the IP so it will work. and 2. how can I check the fuel adjustment to see if it's been messed with since I was told it had a bigger turbo installed at one time.
I will move on to the turbo after this. it has a GM8 installed and the waste gate has been wire tied closed. I have a genuine turbo master I was given with the truck, and also on the 6.2 I have a GM3 (i think) turbo which has the factory non-vacuum waste gate actuator. not sure which I should use, but was wanting a similar setup like I have tuned my 95 where I won't have high boost pressures while cruising on the freeway. (No I don't need a bigger turbo with how I drive)
