Folks,
I've been looking for a thread to tell me how to properly disassemble and reassemble the rear drum brakes on my '99 C3500 dually. I've found threads without pictures that use vocabulary that I don't understand. If someone can point me to an illustrated thread on this, I'd appreciate it. Or, if folks are willing to talk me through the process, I'll take lots of pictures and document it here.
I've read lots of discussion about various axle configurations. I attached photos of my diff and hub, which I hope will clearly document which configuration I have.
Depending on which thread I believe, my next step should either be:
I've ordered a set of service manuals, but if possible, I'd like to make progress on this while I wait for them to arrive.
Thanks in advance,
-jpg
- Soak the drum/hub interface with penetrating oil and use hammers to break it loose and slide it off the hub. or
- Remove the peripheral and central bolts from the hub, remove some "clips", and remove the axle.
Thanks in advance,
-jpg
