I had some nv4500 parts cryotreated,they all broke except one.
Talked to Delta cams today,he recommended their 206 regrind. I think Ill get one done,only $137.
It shouldn't be hard to find springs,might even consider beehive. Don't know if Delta's cam will go past 5000 rpms. Another question,would stainless steel Manley valves work in a diesel ? I think it would be ok,at least for the intake valve.
Degrees Overlap:65 Deg
Not sure how they came up with that,there is no overlap at all.Huh? If this is the same 'overlap' that I'm thinking, that's 65 degrees of crank rotation that BOTH valves are open at the same time.. Doesn't seem right, Idunno.
Maybe that's the magic? But you would think that with any kind of boost, it'd be like blowing the fuel from the cylinder..
By shaving the piston down to 18:1 you could gain some clearance to get the exhaust valve closure closer to TDC, or machine valve reliefs instead for the most clearance while maintaining at least 18:1 CR.
