Found this on SS diesel site, not real sure of the manufacturer though and kinda pricey at 599.00
Performance Roller Camshaft kit for all 6.5's in all trucks, all years, all VIN's.Includes a custom ground performance roller cam, new hydraulic roller lifters, and a free tube of cam assembly lube.Add power to your 6.5TD with our performance cam kit.
Specs as follows...
Advertised Duration (Exhaust):300 Deg
Advertised Duration (Intake):260 Deg
Cam Lift (Exhaust):.281"
Cam Lift (Intake):.281"
Cam Timing at .050" Lobe Lift (Exhaust Close):17 Deg BTC
Cam Timing at .050" Lobe Lift (Exhaust Open):39 Deg BBC
Cam Timing at .050" Lobe Lift (Intake Close):11 Deg ABC
Cam Timing at .050" Lobe Lift (Intake Open):13 Deg ATC
Degrees Overlap:65 Deg
Duration at .050" Lobe Lift (Exhaust):202 Deg
Duration at .050" Lobe Lift (Intake):178 Deg
Lobe Centerline (Exhaust):120 Deg
Lobe Centerline (Intake):101 Deg
Valve Lash (Exhaust):Hyd.
Valve Lash (Intake):Hyd.
Valve Lift (Exhaust):.422"
Valve Lift (Intake):.422"
Not real sure how this cam would behave with 300* ex duration.
