Pull the easy glow plugs and leave the PIA ones alone. You don't need to prime all 8 injectors. Use an IR temp gun on a cold engine and check each area around the glow plug. Cycle the plugs several times. Recheck the temp ... any that didn't change may be bad or bad wires.
Use the block heater overnight and glow plugs are taken out of the picture. It should start on block heater alone.
This is what it should sound and look like priming the fuel system. Some glow plugs out of engine for priming, but NOT all, when the project was being finished.
1992 6.5TD Rescue
.......Any bets on how many parts I still have to replace on the AC system?........i say 5. what's my prize?
www.thetruckstop.us
