NVW
I would pull the fuel shutoff sol, it's the size of a roll of coins on the front top of the IP with two wires. plug it in while removed to see if the plunger pulls in. JM $.02
Leo
Leo
I dunno, now it just cranks over and tries to kick but won't actually start. Before it would start and run, but die.
Any idea what the solenoid is worth?
NVV, i tought i did mention that thing, so, dont take all the creditYou got a good point Matt,but if it would be a IP prob he would get codes.
It wont hurt to check fuel flow at the IP inlet,Maybe he has air in the fuel and dont recognize it.
DIntermittend Shut off sol could cause it too. APP,PMD, grounds
Ahh,so many possibilitys.:
Did you put the sol. back in without the wires connected? If so it won't work. The plunger can be removed, I think it just takes snap ring pliers to remove a snap ring then pull the plunger out.
Leo
NVV, i tought i did mention that thing, so, dont take all the credit![]()
Would i have to do anything with the wiring if i put it back in without the plunger in it?
