Heartbeat Hauler
A(ACLU) Agent Yoda
Man! Where do you guys find this obscure info on our trucks? I am in awe...:hail:
Jeff the 2001 trucks only came with 105 and 130 amp alternators...your RPO code on the glove box should be k68 for 105 amp alternator.
supposedly the snow plow prep pkg changed it over to 130amp
some have reported that their sticker says 130 amp option...
but if your glove box rpo code is k68 it is a 105 amp...
Must be way different...Is an LBZ much different than an LB7? I didn't remove anything when I changed mine and the only tool I used was the ratchet to pull the idler back. Not the easiest belt to change but could have been worse.
John you're such a show-off!:hihi:It is a ROYAL pain in the ass ! Well it is if you actually do it, I had low stress as I watched a pro work his magic! :hihi:
