As much as I dislike multiple connection points due to potential leak points, I was thinking of doing something similar due to routing.Mine still has that green hose with the aluminum pipe up to where the quick connect was. the quick connect was replaced with a straight pipe to barb fitting and a short section of heater hose to couple the aluminum pipe to the barb. the pipe should have a bump where it locked in the quick connector that when a hose is slid over it and clamped, it won't come back off with the coolant pressure.
No problem.AnytimeThank you.
Are you saying you keep the factory aluminum line, otherwise, then?I normally take a hacksaw or whizzer to the lock collar and slit it along the length . Use a screwdriver and pry open the collar , it should fall off . After that it's hose replacement time .
