n8in8or
I believe some people prefer Victor Reinz over Fel Pro. I don't have experience with them personally, but I wouldn't be afraid to use them.Fel Pro or Mahle seem to be the go to. What about Victor Reinz?
So any updates here?
Ordered gaskets. The sale for my other project truck fell through so trying to figure out budget for heads. What is the part number of the Flowkooler pump for the bolt-on fan clutch?
www.flowkoolerwaterpumps.com
1996-1999 6.5L GM Chevy Hummer 6.5L Diesel hi flow water pump
Flowkooler's 1677 pump fits the 1996-1999 395/6.5L Diesel. It has a CNC machined billet impeller designed with an increased vane count and a reduced impeller clearance to achieve greater flow rates, higher head pressure and a more efficient flow than other OEM water pumps. Type II Class II...www.flowkoolerwaterpumps.com
Air to water will be alot more maintenance. So I guess the GM radiator has plastic tanks?
What was wrong with the Cummins radiator?
If the tanks on the new radiator are metal just move the outlet on it.
All aluminum Cummins radiator while costing more $$$ will be easy to weld bungs etc. for the extra lines.
Low speed trans fluid heat is generally because of high stall converter and or other issues.
I fit a Ram Cummins rad, CAC a GM AC condenser and a medium truck trans cooler behind the dual headlight header panel/grille.So the Cummins radiator does not have an internal trans cooler, so I am running a larger than stock external only cooler. It is the same size as the stock oil cooler for reference. The situations where temps were uncontrollable were while towing either a loaded hay trailer or camp trailer, 10 mph or less, 1st or 2nd gear so converter unlocked. There isn't enough airflow through the external cooler alone to remove enough heat to keep the fluid temperature under control. There isn't room between the cooler and grill for an e-fan, so I am going to put the internal radiator cooler back in to the circuit to provide cooling at low vehicle speeds. The external cooler works very well as long as I am moving at a higher speed, but not in those situations.
