New master cylinder went in this evening...and it's no different. If anything it's worse! I didn't think the master would be the problem and this shows it wasn't. I have now replaced everything in the clutch and transmission system, with the exception being the clutch line, which was also new with the previous master in late 2017/ early 2018 so I don't think there's an issue there.
Also overfilled by 1 quart with OEM fluid and of course it didn't make a difference.
The hard shifting happened a week or so before swapping transmissions. When I pulled the bellhousing and saw the fork pivot ball stud was snapped off, I figured this was the reason the clutch wasn't fully disengaging. However with everything else replaced this issue hasn't gone away.
The only 2 things that are different from when the clutch was previously working fine are:
1) the long snout pilot bearing
2) the adjustable throw- out bearing
I'm suspicious of the throw out bearing for the following reason: When I adjusted and set the bearing, there were extra threads sticking past the bearing face. I called the folks at Novak and asked about this feature and was told that this shouldn't interfere with the clutch.
here is the stock bearing on left that came with the south bend clutch kit, Novak adjustable bearing set to spec on the right
Does anyone think this could be getting in the way of the clutch fully disengaging?
Is there any way the long snout pilot bushing could be interfering at all?
I know for a fact the slave cylinder moves, I can see it through the inspection hole in the bellhousing when I block the clutch pedal with a piece of wood. I don't think it's moving as far as it can though, as I don't see the fluid in the master cylinder drop too much and clearly something is stopping the clutch from fully disengaging.
@Twisted Steel Performance, I know your bearing was adjusted even larger than mine, but did you have any exposed threads like my bearing does?
Everything possible has been loaded and fired in the parts cannon with no change in result, so I don't know what else it could be aside from something already present in the system. Thoughts?
