Husker6.5
Can you measure tush torque with that butt-dyno?:biggrinjester:
I have the complete wh1c turbo, so no need to machine the h1c housing for the larger compressor wheel. Plus the wh1c compressor housing has the slots cut into the intake, not sure what they are called right now (MWE?). What purpose do these serve and are they necessary for a low boost application like I will be running? I say low boost because I will not be boosting the full potential of this turbo on my motor.
What pressures y'all run? And an hx-35 from an offroad equipment is slightly different than the dodge version.we are talking 1.5-2mm of difference, not even enough to have to machine the housings to swap stuff around.... we have tried all the configurations of all the versions of H1C used on the dodges, and the WH1C, and a hx-35 off of a Feller/Buncher( industrial 6bt) everything mixed and matched( 17 different versions since march) and i can say from our testing that the most difference on the butt-dyno was changing exhaust housings.... the minimal difference in wheel sizes was not noticable in egts, boost, or butt-dyno....:thumbsup:
we run 25-30 psi boost on this motor ( 457 hrs. worth) normal driving we see anywheres from 3-15 psi, with hard throttle runs up to 30psi..... the only difference with the hx 35 was a 12 cm2 non gated housing, and a slip on connection versus the v-band, the measurements were identical on both wheels, 56mm 83mm/69.5mm 60mm... took the measures for the stock 1996 35 from a friend with a dodge on another site.... his was running the 12cm2 gated housing.... the configuration we are running now is a 56/69/16 wh1c/hx-35/h1c mix... gotta love the v-band CHRA attachment, gives the ease of changing stuff right on the truck.... the snap ring is alright, but can cause finger carnage if it slips under tension, ask me how i know...:rolleyes5:
Size isn't the who story....
I'm not exactly sure why anyone would run such a small turbo on this size of engine. We use hx-35s on 3.8 liter engines. I wouldn't go much smaller than hx-40 .
This is true, although if you know what to get you can walk through a scrap yard an pick up bigger turbos just as cheap . Most scrap yards have no clue.
Look for medium duty diesel trucks.
I know the 8.3 cummins and cat 3126 have nice turbos on them in our size range.
400 for the hx40, is it ready to go?
I went to Craigslist to see if it was still listed, but couldn't find it, so apparently gone. The big point for me is I just don't have that much cash available right now.
Don
