Is that single electric fan all you use for cooling? Have you tried fitting a set of late model camaro fans in there? Have you considered running a 4bt instead of a 6? I would think the extra room would make the swap alot easier, and a properly setup 4bt with twins can make more than enough power to tear up a 4l80e.
Not everything in the setups are my choice, I work with the owners and set them up per what they want. You can explain the hazards all day long, but when the have "cool factor" on their minds there is no swaying them. You may be astounded by the thinking, but what comes into play is "I want to hear that turbo spool!" or/and "I want people to hear the Blow Off when I back out of it". Yes, these are actual grown men. Yes, they understand that ingestion of sand will destroy the motor over time. Ha! Know what the answer is?Nice build, I'm surprised your not running a canister filter with a snorkel playing in the sand.
