Not to get in a whizzin contest, over cooling theory and rates of flow vs what GM did with dual stat & 130 gpm, I'll offer up this point.
The 130 gpm dual stat set up was modeled for a 6.5 making 195 flywheel HP and towing at operators manual published towing limits, and some steady state speed which most of us probably don't drive at; so there is a distinct possibility that the flow model is incorrect for those that do more than that with our trucks.
My 98 Burb new to me in 2006 was overheating in traffic, I deep cleaned the rad and things got better, but I was not happy with it still, so I bought the full H2O kit from Heath, new pump ala 6.2 latest style IIRC, swapped to a single stat from the dual it came with, tweaked down heater bypass nipple, added plastic fan/spin on clutch, and I could not be happier or running cooler.
Not much special about the Burb power adder wise reflash, PMD remoted, TM, & 4" exhaust it's a people hauler, my K1500 all mods in sig including balance flow (not really necessary now for most 6.5ers per Bill if going with his latest H2O kit), never gets over 195F coolant, 100F days moving 18K# loads, (that one is still 97+ GM statted/pumped)stock rads though on both vehicles.
My point is THE GM fix may not be THE fix, as most aren't running to that power band anymore, IMO if one looks at the flow calcs GM used I think maybe 130gpm is too much flow, that flow is so fast that proper time in rad for water is on ragged edge for proper heat xfer to occur, and that we know 95gpm is not enough flow , maybe better flow is 110-120 gpm.
I don't know what Bill's single stat set up is flowing, but remember this was on the LSR at Bonneville in desert salt flat, and keeping things cool to 153 mph, so something to consider.
